- HANNS.G HP191DJ0 - HP Series - LCD monitor - 19"
- LCD monitor - 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 15000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Silver
- 41 cm x 20.3 cm x 39.3 cm
- 5 kg
- Environmental Standards
- ENERGY STAR Qualified
- GOST, GS, CB, RoHS
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese, Korean
- HDCP
- Silver
- 5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (dual link) , Audio line-in
Mechanical
- Height, tilt
- Tilt Angle
- 20
- Height Adjustment
- 60 mm
- VESA Mounting Interface
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85%
