HannsG HE225DPB 21.5" 1920x1080 Full HD VGA DVI LED Monitor
BUILT IN SPEAKERS!
Quicklinx: 8PKCWS00 Mfr#: HE225DPB
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
42 in stock
£67.23 ex VAT
£80.67 inc VAT
HannsG has built up a wealth of experience and knowledge in display technology making them a leader in the global monitor market. Each HannsG monitor is carefully crafted to deliver a perfect harmony of design, performance and practicality, and the wide range enables you to select the right monitor for you, no matter how specific your requirements might be.
Hannspree HE225DPB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 40000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
51.28 cm x 18.5 cm x 36.74 cm
3.12 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
UL, GOST, cUL, CB, CCC, FCC
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP
3.12 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
DVI-D (HDCP) , VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-3/+17
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m
24 Watt
Power Consumption Stand by / Sleep
1.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
TCO Certified
5 °C
35 °C
20 - 85% (non-condensing)
HannsG HE225DPB 21.5 Bundle deal on HannsG HE225DPB 21.5" 1920x1080 Full HD VGA DVI LED Monitor
£166.40
8PKC StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
8PKC StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
8PKC StarTech.com Articulating Monitor Arm In Stock £89.19
8PKC StarTech.com Dual Monitor Stand In Stock £69.36
8PKC StarTech.com Cubicle Monitor Hanger In Stock £45.29
8PKC StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
8PKC StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: HannsG
Price Range Ex VAT: 50 - 100
