- HANNS.G HE196APB - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- Black
- 44.6 cm x 14.76 cm x 34.5 cm
- 2.3 kg
- Display Type
- Diagonal Size
- 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 61 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Korean
- Black
- 2.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Voltage Required
- AC 100 V (50/60 Hz)
- 20 Watt
- Power Consumption Stand by
- 0.5 Watt
- 5 °C
- 35 °C
- 20 - 85% (non-condensing)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £110.82 |
StarTech.com Articulating Monitor Arm | In Stock | £103.13 |
StarTech.com Dual Monitor Stand | In Stock | £70.24 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.79 |
