- Quad Core IntelĀ® Atom Z3735F Processor up to 1.83 GHz
- Pocketable Micro PC Experience
- Transform any HDMI Dispay in to a Computer
- Ultra Mobile PC
- 2GB Ram & 32GB Storage
- Super Slim design / Brushed metal finish casing
- Specifically designed for your needs
- Windows 8.1 pre-installed
Compact Design and Versatile
Whether it's at home or in the office, the HANNspree Micro-PC is perfect for all your needs thanks to its space-saving design and versatile placement options.
Pocketable PC Experience
The HANNspree Micro PC is one of the smallest computer in the market. Just load it up with your digital content and slip it in your pocket to bring your HD video and personal data anywhere. A full PC experience in less than 10cm and 40 grams.
Specifically Designed for Your Needs
No longer the size or noise steal the scene for your computing needs. The HANNspree Micro-PC is easy to hide for a new experience that is out of sight and sound.
Compact design and versatile
Whether it's in your house or office, the HANNspree Micro-PC is perfect for all your needs thanks to its space-saving design and versatile placement options. -
Pocketable PC experience
The HANNspree Micro PC is one of the smallest computer in the market. Just load it up with your digital content and slip it in your pocket to bring your HD video and personal data anywhere. -
No longer the size or noise steal the scene for your computing needs. The HANNspree Micro-PC is easy to hide for a great experience that is out of sight and sound. -
Connecting to Wi-Fi networks
Built-in hi-speed Wi-Fi module, will provide you with fast access to all things you like and will help you stay in touch with your friends, family and business partners using emails and social networks. -
Bluetooth
Share content on your HANNspree Micro-PC with other devices quickly and easily. Activate the Bluetooth connections, synchronize the devices and job done! You can transfer any file in a matter of seconds - with no need for cables or Internet connections. -
Micro SD expansion slot
A Micro SD expansion slot supports an additional 128GB of storage.
- Hannspree Micro PC - Micro PC - Atom Z3735F 1.33 GHz - 2 GB - SSD 32 GB
- Personal computer - Micro PC
- Processor
- Intel Atom Z3735F / 1.33 GHz (, up to 1.83 GHz, (Quad-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 2 GB DDR3 SDRAM
- Hard Drive
- SSD 32 GB - eMMC
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel HD Graphics
- Networking
- 802.11b/g/n, Bluetooth 4.0
- OS Provided
- Windows 8.1
- 11.09 cm x 3.8 cm x 0.98 cm
- 38 g
- Limited warranty - 2 years
- Personal computer
- Product Form Factor
- Micro PC
Processor / Chipset
- CPU
- Intel Atom Z3735F
- Clock Speed
- 1.33 GHz
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
Hard Drive
- SSD - eMMC
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI
- Wireless LAN Supported
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- 1 x HDMI , 1 x USB 2.0 , 1 x USB - micro-USB
- Included Accessories
- Battery charger
- Cables Included
- HDMI cable
Operating System / Software
- OS Provided
- Windows 8.1
- 11.09 cm
- 3.8 cm
- 0.98 cm
- 38 g
