HannsG 27.5" HZ281 Wide 3MS DVI VGA
Quicklinx: 78RJWS00 Mfr#: HZ281HPB
  • High-Definition Multimedia Interface (HDMI)
Marketing description is not available.
HANNS.G HZ281HPB - LCD monitor - 27.5"
LCD monitor - 27.5"
Stereo speakers
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.309 mm
Brightness
400 cd/m²
Contrast Ratio
800:1 / 15000:1 (dynamic)
Response Time
3 ms (grey-to-grey), 5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
65.3 cm x 25.4 cm x 52.3 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, UL, VCCI, cUL, CB, CCC, PSB, FCC, RoHS, cULus, GOST-R
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
27.5"
Built-in Devices
Stereo speakers
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.309 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
OSD Languages
English, German, French, Italian, Norwegian, Portuguese, Russian, Spanish, Korean
HDCP
8.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x HDMI-DVI cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
95 Watt
Power Consumption Stand by / Sleep
1 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - LCD panel - 1 year , Limited warranty - backlight - 1 year
5 °C
35 °C
10 - 85%
