HannsG 15.6" 1366 x 768 HDMI VGA LED Black Touch Screen Monitor
Quicklinx: CYQLWS00 Mfr#: HT161HNB
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 12ms
Speakers: Headphone
Interfaces: HDMI, VGA (HD-15)
47 In Stock
£151.54 ex VAT
£181.84 inc VAT
With 10 point-touch Projective Capacitive technology the HANNSpree HT161HNB delivers seamless and accurate touch response.
Featuring LED-backlight LCD screen technology, it offers exceptional colour performance making it an excellent choice for a vast array of demanding interactive applications.
Perfect for both commercial and consumer applications, the HT161HNB is a one-stop solution for your multi-touch monitor needs.
HANNS.G HT161HNB - HT Series - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Energy Class
Class B
Energy Consumption per Year
9 kWh
Power Consumption (On mode)
6 W
Touch-screen
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
220 cd/m²
Contrast Ratio
500:1 / 40000000:1 (dynamic)
Response Time
12 ms (typical)
Colour Support
262,000 colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
AC 100/240 V (50 - 65 Hz)
37.44 cm x 15 cm x 28.9 cm
1.2 kg
3-year warranty
Display Type
Energy Class
Class B
9 kWh
Diagonal Size
15.6"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
220 cd/m²
Contrast Ratio
Colour Support
262,000 colours
Response Time
12 ms (typical)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 61 kHz
Horizontal Viewing Angle
110
Vertical Viewing Angle
85
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
1.2 kg
Audio
Headphone
Input
Touch-screen - touchscreen
Movement Detection Technology
Capacitive
VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
15/+50
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), wall mountable, VESA interface support
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m , 1 x USB cable - 1.8 m
Input Voltage
6 W
6 kWh/1000h
Power Consumption (Typical)
10 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Limited warranty - 3 years
Response Time: 12ms
Speakers: Headphone
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HannsG
