Hama Ultraslim Fullmotion TV Wall Bracket 56"
Quicklinx: D1S8WS00 Mfr#: 00108749
The extremely flat profile of Hama's Ultraslim Fullmotion Wall Backet allows for modern and space-saving interior design. The Easy-Fix system means simple installation and fully adjustable orientation of your TV.An intergrated cable manager provides organisation and necessary strain relief.
Hama "Ultraslim" FULLMOTION TV Wall Bracket, 3 stars, L - mounting kit - for flat panel - black
Mounting kit - wall-mountable
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-56"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 800 x 500 mm, 800 x 800 mm, 400 x 300 mm, 50 x 50 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 200 mm, 300 x 100 mm, 600 x 600 mm, 200 x 100 mm, 800 x 600 mm, 800 x 200 mm, 300 x 300 mm, 600 x 300 mm, 600 x 500 mm, 200 x 300 mm, 300 x 400 mm, 600 x 800 mm
Max Load Weight
25 kg
Material
Steel
Material
Steel
AV Furniture
Mounting kit
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
32"-56"
Adjustments
Tilt
Max Load Weight
25 kg
Swivel adjustment
