Hama Tilt TV Wall Bracket 65" Black
Quicklinx: D1SFWS00 Mfr#: 00118105
The Hama Tilt TV Wall Backet has an Easy-Fix system for simple installation and offers fully adjustable orientation of your TV. It also has an integrated spirit level for fast and easy mounting.
Hama TILT TV Wall Bracket, 1 star mounting kit - Easy-Fix - for TV - black
Mounting kit (Easy-Fix) - wall-mountable
Mounting Components
Wall bracket, mounting hardware
Integrated Devices
Spirit level
42 cm x 2.8 cm x 42 cm
Tilt
-12°
Recommended Use
TV
Recommended Display Size
32"-65"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 400 mm, 300 x 300 mm
Max Load Weight
35 kg
Material
Steel
42 cm
2.8 cm
42 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Design
Easy-Fix
Recommended Use
TV
Placing / Mounting
Wall-mountable
Integrated Devices
Spirit level
32"-65"
Tilt
-12°
Max Load Weight
35 kg
