Hama Tilt TV Wall Bracket 42" Black
Quicklinx: D1S2WS00 Mfr#: 00084426
Hama's well designed and extremely flat profile make this wall mount perfect for space saving. The easy-fix system and fully adjustable orienatation is simple to use.
Hama "Next Light" - mounting kit - for flat panel - black
Mounting kit - wall-mountable
44 cm x 4.2 cm x 18.5 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
23"-42"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 200 x 300 mm, 300 x 400 mm
Max Load Weight
50 kg
Material
Steel
44 cm
4.2 cm
18.5 cm
Material
Steel
AV Furniture
Mounting kit
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
23"-42"
Adjustments
Tilt
Max Load Weight
50 kg
