Hama Tilt TV Wall Bracket 37" Black
Quicklinx: D1S6WS00 Mfr#: 00084425
£25.73 ex VAT
£30.87 inc VAT
Easy flat screen installation with Hama's Tilt Wall Bracket. The flat profile means that it is well hidden behind the TV and saves space in your room.
Hama "Next Light" - mounting kit - for flat panel - black
Mounting kit - wall-mountable
28 cm x 4.2 cm x 14 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
10"-37"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Material
Steel
28 cm
4.2 cm
14 cm
Material
Steel
AV Furniture
Mounting kit
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
10"-37"
Adjustments
Tilt
Max Load Weight
25 kg
Brand: Hama
