Hama Star 63 Tripod with Case
Quicklinx: 7L8XWS00 Mfr#: U1004163
Type: Tripod
£32.09 ex VAT
£38.50 inc VAT
  • Sturdy construction
    Made from high-quality aluminum, the tripod ensures robustness and reliability during outdoor and indoor use.
  • Versatile height adjustment
    With a maximum height of 166 cm and a minimum of 66 cm, the tripod allows users to capture images from various perspectives.
  • Quick release functionality
    The quick release system facilitates prompt mounting and dismounting of cameras, streamlining the workflow.
  • Secure locking mechanism
    Equipped with flip lock lever legs, the tripod maintains stability on uneven terrain while ensuring easy adjustments.
  • Practical carrying solution
    The included case provides protection and ease of transport, making the tripod suitable for on-the-go photographers.
Hama Star 63 tripod
Tripod
1.74 kg
Champagne
Head Type
Pan
Tripod Operating Height
66 cm - 166 cm
Max Supported Weight
4 kg
Tripod
Folded Length
166 cm
1.74 kg
Champagne
Material
Aluminium
Tripod
Tripod Legs Sections Qty
3
Tripod Legs Lock Type
Flip lock lever
Quick Release System
Tripod Centre Column Type
Geared
Max Operating Height
166 cm
Min Operating Height
66 cm
4 kg
Supported Devices
Camcorder, camera
Accessory hook, leg braces
Head
Head Type
Pan
Head Positioning
3-way
Tripod Mount
1/4" screw
Case
Type: Tripod
Brand: Hama
