Sturdy construction
Made from high-quality aluminum, the tripod ensures robustness and reliability during outdoor and indoor use. -
Versatile height adjustment
With a maximum height of 166 cm and a minimum of 66 cm, the tripod allows users to capture images from various perspectives. -
Quick release functionality
The quick release system facilitates prompt mounting and dismounting of cameras, streamlining the workflow. -
Secure locking mechanism
Equipped with flip lock lever legs, the tripod maintains stability on uneven terrain while ensuring easy adjustments. -
Practical carrying solution
The included case provides protection and ease of transport, making the tripod suitable for on-the-go photographers.
- Hama Star 63 tripod
- Product Type
- Tripod
- 1.74 kg
- Champagne
- Head Type
- Pan
- Tripod Operating Height
- 66 cm - 166 cm
- Max Supported Weight
- 4 kg
- 2-year warranty
- Product Type
- Tripod
- Folded Length
- 166 cm
- 1.74 kg
- Champagne
- Material
- Aluminium
Tripod
- Tripod Legs Sections Qty
- 3
- Tripod Legs Lock Type
- Flip lock lever
- Quick Release System
- Tripod Centre Column Type
- Geared
- Max Operating Height
- 166 cm
- Min Operating Height
- 66 cm
- 4 kg
- Supported Devices
- Camcorder, camera
- Accessory hook, leg braces
Head
- Head Type
- Pan
- Head Positioning
- 3-way
- Tripod Mount
- 1/4" screw
- Included Accessories
- Case
- Limited warranty - 2 years
