Hama RF2200 Wireless UK Keyboard
Quicklinx: CVPZWS00 Mfr#: 73053817
Hama's RF2200 Keyboard is black, its also wireless and comes with a nano reciver. It has a slim design, and comes with a convenient height adjustment for added comfort. It also has a splash proof design, thanks to the drain. The keyboard consists of 105 key layout. For all of you that type loudly, and would prefer your typing to be a little more subtle, then this is the keyboard for you! Due to the soft touch keys it allows smooth and quiet keystrokes. It is suitable for all standard PC's. It also includes Smart-Link technology for an easy start up.
  • Protection from splashes of water thanks to liquid drain.
  • Softtouch keys for smooth and quiet keystrokes.
  • Laser-etched buttons for a high resistance to wear.
Hama "RF 2200" - keyboard - black
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Keys Qty
104
43.5 cm x 12.5 cm x 2.5 cm
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Keys Qty
104
43.5 cm
12.5 cm
2.5 cm
Microsoft Windows Vista / XP / 7
AAA type
Installed Qty
1
Required Qty
1
