The Hama Dustcover for monitors helps to protect against dust, dirt and liquid. For wide screen monitors with a screen size of 24" to 26" and created with tearproof material.
- Hama monitor protective cover - 24" - 26" wide
- Product Type
- Monitor protective cover
- Transparent
- Display Screen Size Compatibility
- 24" - 26" wide
- 62 cm x 8 cm x 44 cm
- Product Type
- 24" - 26" wide
- 62 cm - 8 cm - 44 cm
- Transparent
