Product
Hama Monitor Dust Cover 24"/26" - Transparent
Quicklinx: D1SJWS00 Mfr#: 00084183
£6.55 ex VAT
£7.86 inc VAT
The Hama Dustcover for monitors helps to protect against dust, dirt and liquid. For wide screen monitors with a screen size of 24" to 26" and created with tearproof material.
Hama monitor protective cover - 24" - 26" wide
Monitor protective cover
Transparent
Display Screen Size Compatibility
24" - 26" wide
62 cm x 8 cm x 44 cm
24" - 26" wide
62 cm - 8 cm - 44 cm
Transparent
Hama Monitor Dust Cover 24 Bundle deal on Hama Monitor Dust Cover 24"/26" - Transparent
£106.31
Brand: Hama
Price Range Ex VAT: 0 - 50
