Product
Hama Mini Screwdriver Kit
Quicklinx: D1SLWS00 Mfr#: 00039694
Hurry, only 3 left in stock!
£9.30 ex VAT
£11.16 inc VAT
The fantastic Mini Screwdriver Kit from Hama, will provide you with the ultimate solution to your loose screws and broken products (particularly electrical devices), with its collection of different sized and shaped drivers, all of which are stored in a compact elegant pouch made from artificial leather which can easily be transported to and from the office so no matter where you are, you can rest assured that you will always have your tools with you. The kit comprises of 3 slotted driver bits, 3 recessed driver bits, 6 torque driver bits and a high quality solid full metal handle with corrugated non-slip surface for attaching your drivers securely and maintaining a firm grip whilst working. Furthermore, being so compact, the kit can easily fit in your trouser pocket if you are without a bag to store it in.
Hama Mini Screwdriver Kit - screwdriver with bit set
Screwdriver with bit set
Tip
T5, T6, T7, T8, T9, T10, PH000, PH00, PH0, SL1.5, SL2.0, SL2.5
Holder
Case - artificial leather
Tip Size
Slip-resistant handle
Holder
Case
Material
Artificial leather
Brand: Hama
Price Range Ex VAT: 0 - 50
