The fantastic Mini Screwdriver Kit from Hama, will provide you with the ultimate solution to your loose screws and broken products (particularly electrical devices), with its collection of different sized and shaped drivers, all of which are stored in a compact elegant pouch made from artificial leather which can easily be transported to and from the office so no matter where you are, you can rest assured that you will always have your tools with you. The kit comprises of 3 slotted driver bits, 3 recessed driver bits, 6 torque driver bits and a high quality solid full metal handle with corrugated non-slip surface for attaching your drivers securely and maintaining a firm grip whilst working. Furthermore, being so compact, the kit can easily fit in your trouser pocket if you are without a bag to store it in.
- Hama Mini Screwdriver Kit - screwdriver with bit set
- Product Type
- Screwdriver with bit set
- Tip
- T5, T6, T7, T8, T9, T10, PH000, PH00, PH0, SL1.5, SL2.0, SL2.5
- Holder
- Case - artificial leather
- Product Type
- Tip Size
- Slip-resistant handle
Holder
- Case
- Material
- Artificial leather
- Warranty
- 2 years
