- For the installation of TFT/LCD/LED monitors with a screen diagonal of up to 66 cm (26")
- Integrated high-performance pneumatic spring for vertical, fully adjustable orientation
- 360° rotation for horizontal or vertical orientation
- Swivel arms for maximum rotation
- The retaining system keeps your workplace tidy and allows you to work ergonomically
- Cable manager provides organisation and necessary strain relief
- Swivel range on 3 hinges: up to 360°
- Swivel range up to 180°
- Inclinable +/- 90°
- Supports all VESA standards up to 100x100
- Table fastening with clamping screw (table top thickness up to max. 10 cm) or drill-secured mounting
Note for Consumers: To ensure that the holder is height adjustable, a minimum supported load of around 1.5 kg is required.
Technical Details: - Maximum Load: 5 kg - Model: Monitor Arm - Monitor Fixation Standart: VESA incl. Adapter Plate - Rotation Range: 360 ° - Tilt +/-: 90 / 90 ° - Adjustable Distance: Yes - Max. Monitor Size: 66 cm - VESA Standard: 100 x 100 mm - Width x Depth x Height: 11,5 x 52,2 x 11,2 cm - Colour: Black - For Monitors: 26" - For a Table Top Thickness of: 10 cm
- Hama FULLMOTION mounting kit - adjustable arm - for Monitor - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 11.5 cm x 52.2 cm x 11.2 cm
- Tilt
- -90° to 90°
- Pan
- 360°
- Rotation
- 360°
- Adjustments
- Lift
- Recommended Use
- Monitor
- Recommended Display Size
- 26"
- VESA Mounting Interface
- 100 x 100 mm
- Max Load Weight
- 5 kg
- Black
- Package Content
- Mounting hardware
- 2-year warranty
- 11.5 cm
- 52.2 cm
- 11.2 cm
- Black
- Package Content
- Mounting hardware
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- 100 x 100 mm
- Cable Management
- Integrated cable management
- 26"
- Tilt
- -90° to 90°
- Pan
- 360°
- Rotation
- 360°
- Adjustments
- Lift
- Max Load Weight
- 5 kg
- Limited warranty - 2 years
