The Hama CD, DVD and Blue-ray storage wallet has high quality, anti-static sleeves and a maximum capciaty of 120.
- Hama CD Wallet 120 - wallet for CD/DVD discs
- Product Type
- Wallet for CD/DVD discs
- 29.4 cm x 16.6 cm x 9.4 cm
- 473.3 g
- Supported Media Qty
- 120 discs
- Material
- Nylon
- Black
- 2-year warranty
- 29.4 cm
- 16.6 cm
- 9.4 cm
- 473.3 g
- Material
- Nylon
- Black
Carrying Case
- Wallet
- Recommended Use
- For CD/DVD discs
- Carrying Strap
- Wrist strap
- 120 discs
- Foam padding, antistatic
- 2 years
