Hama "Bend" Portfolio for Apple iPad Pro 12.9" Black
Quicklinx: D1TLWS00 Mfr#: 00106434
Protect your iPad Pro 12.9" with Hama's "Bend" Portfolio. The integrated magnet turns the iPad on when the lid is opened and off when it is closed.The stand function allows for easy positioning of your tablet.
Hama "Bend" Portfolio - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
12.9"
23 cm 31 cm
310 g
Material
Polyurethane
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
23 cm
31 cm
310 g
Material
Polyurethane
Carrying Case
Protective cover
Recommended Use
For tablet
12.9"
Protection
Dust-resistant, scratch-resistant, dirt-resistant
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Inner Dimensions
22.1 cm x 0.7 cm x 30.6 cm
Cover Features
Stand function
2 years
