Protect your iPad Pro 12.9" with Hama's "Bend" Portfolio. The integrated magnet turns the iPad on when the lid is opened and off when it is closed.The stand function allows for easy positioning of your tablet.
- Hama "Bend" Portfolio - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 12.9"
- 23 cm 31 cm
- 310 g
- Material
- Polyurethane
- Black
- 2-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
- 23 cm
- 31 cm
- 310 g
- Material
- Polyurethane
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 12.9"
- Protection
- Dust-resistant, scratch-resistant, dirt-resistant
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Magnetic closure
- Inner Dimensions
- 22.1 cm x 0.7 cm x 30.6 cm
- Cover Features
- Stand function
- 2 years
- Designed For
