Gunnar MLG Phantom Gloss Onyx - Gaming Glasses
Quicklinx: 8S5SWS00 Mfr#: PHA-00101
MLG PHANTOM
When there's no time to blink, the Phantom doesn't disappoint. With the second largest lens coverage in the ESPORT series, its highly wrapped configuration and headset compatible temples help achieve an optimal visual experience. Fueled by GUNNAR's i-AMP lens technology, the MLG Phantom is a vital component to help you nab those extra frags.
  • Adjustable silicone nose pads provide a customizable fit
  • Fastener free hinge design and high tensile steel construction create incredible durability
  • Gently curved temples provide necessary retention to keep eyewear in place
  • Ultra slim temples distribute headphone pressure to ensure headset compatibility
  • Interchangeable sockets create endless design and customization options
  • One piece front construction eliminates all welds, screws and other potential points of failure
What Are Gunnars?
GUNNARS are high tech computer eyewear designed to protect, enhance and optimize your vision.
The Problem:
You spend most of your waking hours glued to your computer screen, smart phone, tablet or TV monitor. As the hours go by, you subject your eyes to harsh, high intensity blue light and glare from your screen. Constant viewing of digital screens can create visual stress, eye fatigue, dry eyes, irritation, and even headaches, leading to an obvious conclusion - staring at a computer for long hours can take a toll on your eyes.
The Solution:
GUNNARS increase contrast, comfort and focus while minimizing eye fatigue and visual stress for anyone who spends long hours staring at digital screens. GUNNAR eyewear is powered by i-AMP lens technology comprised of a proprietary lens material in an advanced geometry tuned for intermediate viewing distance and finished with custom formulated lens filters, tints and coatings.
Benefits of Wearing GUNNARS:
Protects Your Eyes
Eyestrain, visual stress and dry eyes can be caused by extended periods of near to intermediate distance computer viewing. GUNNARs ease the strain and stress by helping your eyes focus more naturally. Less strain on your eyes and an increased ability to focus can help lead to improved productivity.
Improves the Visual Environment
GUNNAR eyewear protects against environmental factors that can cause vision problems in a workplace environment. The lens tint, coatings, and curvature combat issues like harsh fluorescent light, glare, and ambient air currents that cause your eyes to dry out.
Improves Detail and Focus
GUNNAR's lens tint, anti-glare coatings, and ultra-pure lens material help provide sharper, clearer vision. GUNNAR lens geometry includes extra focusing power to protect against fatigue from eye muscles straining over extended periods of time. The added power also enhances detail.
Reduces Eye Fatigue
The overabundance of bright artificial light from a digital screen and office lighting can create a strain on your eyes. GUNNAR eyewear filters out the harsh, high energy part of the spectrum and creates a more relaxed viewing experience. If your eyes stay fresh then you can focus longer, work more efficiently, and feel more comfortable.
GUNNAR MLG Phantom - glasses - for gaming - frame: gloss onyx - lens: amber
Glasses - for gaming
Frame
Full rim - gloss onyx
Nose Bridge
16 mm
Temple Arm
132 mm
Lenses
Amber
Lens Size
57 mm
25 g
Glasses
Activity / Sport
Gaming
Adjustable nose pads, silicone nose pads, one-piece front construction, flexible temples, interchangeable sockets
Frame
Frame Type
Full rim
Frame Colour
Gloss onyx
Nose Bridge
16 mm
Temple Arm
132 mm
Lenses
Lens Colour
Amber
25 g
