Griffin designed and rigorously tested Survivor All-Terrain to be the most protective case possible for whatever your day has in store. Built from the inside out to meet or exceed the standards published in US Department of Defense MIL-STD-810G, Survivor All-Terrain protects your phone from extreme conditions, including drops, dust, sand, rain, impacts, vibration, and a host of other environmental factors. Survivor All-Terrain's 4 layers of protection start with a foam-lined shatter-resistant polycarbonate frame clad in rugged, shock-absorbing silicone. A built-in screen protector snaps on to seal your touchscreen from the outside environment. Volume and power buttons are covered, and hinged plugs seal the Lightning connector, headphone port, and hold switch. And, to make it easy to carry, a detachable heavy-duty rotating clip secures your phone to your belt or bag strap.
Designed and tested tough
Designed from the inside out to meet or exceed the military standards, Survivor All-Terrain protects your device from extreme conditions, including drops, dust, sand, rain, impacts, vibration, and a host of other environmental factors. -
Slimmer protection
You don't have to sacrifice protection to get a slim, easy-to-use case for your device. Survivor All-Terrain has been redesigned to be thinner than the competitors' rugged cases. A recessed back and an easy-to-grip bumper work together to make this Survivor All-Terrain very easy to hold.
- Griffin Survivor All-Terrain - back cover for tablet
- Product Type
- Back cover for tablet
- 13.7 cm x 2.84 cm x 20.3 cm
- 220 g
- Material
- Silicone, polycarbonate
- Black, blue
- 13.7 cm
- 2.84 cm
- 20.3 cm
- 220 g
- Material
- Black, blue
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Splashproof, shockproof, scratch-resistant, dirt-resistant, sandproof, vibration-proof, drop-proof
- Cover Type
- Back cover
- Included Accessories
- Stand
- Camera lens cutout, port cut-outs, built-in screen protector
- Cover Features
- Stand function
- MIL-STD 810F
