Griffin Survivor Summit for iPhone 7 Plus - Black / Blue
Quicklinx: CN8BWS00 Mfr#: GB42826
Designed to deliver IP-55-rated water resistance, Summit is splash-proof, dirtproof, sandproof and rainproof. Summit's impact dispersion system absorbs impact forces, directing them away from your phone. Summit protects the display and home button with a Touch ID-compatible slide-on screen shield.
  • Mud resistant
  • Impact dispersion system
  • Screen guard
  • Layers of protection
    Shatter-resistant multi-layer construction. Plus, your phone's controls, headphone jack, speakers and microphones are protected from debris and damage.
  • Slim design
    With its slim, rounded design and no-slip grip, Summit is easy to get into and out of your pocket.
  • Belt clip
    Rotating belt clip/video stand makes carrying and viewing easy.
Griffin Survivor Summit - protective case for mobile phone
Protective case for mobile phone
9.19 cm x 1.27 cm x 17.272 cm
79.66 g
Material
Silicone, polycarbonate, thermoplastic elastomer (TPE)
Black/blue
1-year warranty
9.19 cm
1.27 cm
17.272 cm
79.66 g
Rugged
Material
Black/blue
Carrying Case
Protective case
Recommended Use
For mobile phone
Protection
Weatherproof, splashproof, scratch-resistant, impact protection, abrasion-resistant, sandproof, drop-proof
Carrying Strap
Rotating belt clip
Stand
MIL-STD 810G, IP55
Max Height of Shock Resistance
3 m
1 year
