Designed to deliver IP-55-rated water resistance, Summit is splash-proof, dirtproof, sandproof and rainproof. Summit's impact dispersion system absorbs impact forces, directing them away from your phone. Summit protects the display and home button with a Touch ID-compatible slide-on screen shield.
Mud resistant
Designed to deliver IP-55-rated water resistance, Summit is splash-proof, dirtproof, sandproof and rainproof. -
Impact dispersion system
Summit's impact dispersion system absorbs impact forces, directing them away from your phone. -
Screen guard
Summit protects the display and home button with a Touch ID-compatible slide-on screen shield. -
Layers of protection
Shatter-resistant multi-layer construction. Plus, your phone's controls, headphone jack, speakers and microphones are protected from debris and damage. -
Slim design
With its slim, rounded design and no-slip grip, Summit is easy to get into and out of your pocket. -
Belt clip
Rotating belt clip/video stand makes carrying and viewing easy.
- Griffin Survivor Summit - protective case for mobile phone
- Product Type
- Protective case for mobile phone
- 8.103 cm x 1.295 cm x 15.113 cm
- 79.66 g
- Material
- Silicone, polycarbonate, thermoplastic elastomer (TPE)
- White, light grey, clear
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 1-year warranty
- 8.103 cm
- 1.295 cm
- 15.113 cm
- 79.66 g
- Rugged
- Material
Carrying Case
- Protective case
- Recommended Use
- For mobile phone
- Protection
- Weatherproof, splashproof, scratch-resistant, dirt-resistant, impact protection, smudge-proof, shatterproof, sandproof, drop-proof, wear-resistant
- Carrying Strap
- Rotating belt clip
- Included Accessories
- Stand
- MIL-STD 810G, IP55
- Max Height of Shock Resistance
- 3 m
- 1 year
