Griffin Survivor Rugged Folio Flip cover for tablet
Quicklinx: D9F5WS00 Mfr#: GB43544
Survivor Rugged Folio opens and closes like a book to protect your touchscreen when you're not using it. The unique design uses strong hidden magnets to attach and perfectly align the removable tactical grip cover, which resists dirt, grease and stains. Flip the cover open and into a stable stand for watching video. Or adjust it slightly to position your iPad at the perfect angle for typing.
Pull the folio cover away to release the built-in magnets and you've got a contoured shell case that's easy to hold onto while delivering protection from 4-foot (1.2-meter) drops onto concrete. It's ideal for reading and gaming on your tablet.
The built-in magnets are strong enough to hold your iPad on most metal surfaces... think toolboxes, workbenches or whiteboards. Wherever work takes you, the Survivor Rugged Folio lets you post your iPad close by.
Combining military-standard protection against drops with a unique Tactical Grip cover design, Survivor Rugged Folio delivers versatile protection for all the ways you use your iPad.
Griffin Survivor Rugged Folio - flip cover for tablet
Screen Size Compatibility
10.5"
Material
Polycarbonate, thermoplastic polyurethane (TPU)
1-year warranty
Rugged
Material
Carrying Case
Protective cover
Recommended Use
For tablet
10.5"
Protection
Dirt-resistant, impact protection, drop-proof
Cover Type
Flip cover
Open Type
Side
Cover Features
Stand function
Max Height of Shock Resistance
1.2 m
1 year
