Griffin Survivor iPad Air in Black/Blue
PRICE DROP!
Clearance
Price Drop
Quicklinx: 9YT0WS00 Mfr#: GB36403-2
Griffin's Survivor extreme-duty case is designed from the inside out to protect your iPad from extreme conditions: dirt, sand, rain, shock, vibration, and a host of other environmental factors.
Survivor is built on a shatter-resistant polycarbonate frame clad in rugged, shock absorbing silicone. A built-in screen protector seals your multi-touch display from the outside environment, while hinged plugs seal the dock connector, headphone port, hold switch, camera, and volume controls. Survivor is independently tested to meet or exceed environmental testing standards for blown rain, blown dust and grit, vibration, shock, temperature and humidity.
Griffin Survivor - protective cover for tablet
Protective cover for tablet
Material
Silicone, polycarbonate
Black/blue
Material
Black/blue
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Weatherproof, splashproof, shockproof, dust-resistant, sandproof, vibration-proof, drop-proof, wear-resistant
Port covers, built-in screen protector
Cover Features
Stand function
