Get out there. Rain, mud, drops, whatever you're into, Survivor Extreme for iPhone is built to survive. Survivor Extreme is the peak of all-conditions protection.
Protects your phone when the going gets messy
Survivor Extreme's sealed-shell design is engineered to give your iPhone an IP-55 rating against mud, water and debris to prevent scratches and damage to your phone's body and screen. Your iPhones speakers and microphones are sealed with water-resistant membranes to keep you in touch no matter how sloppy things get. -
Easy-install slide-on screen prevents screen damage
Extreme's easy-on sliding screen protector guards your iPhone's multi-touch display from smudges, scratches and more. And it's fully compatible with your Touch ID scanner. -
Durable, ready-for anything belt clip
Extreme's rugged locking clip carries your iPhone clipped on to your waist or a backpack strap. The rotating clip locks open to position your phone perfectly whenever you want to watch videos or make calls on FaceTime.
- Griffin Survivor Extreme - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate
- Grey, black, smoke
- 1-year warranty
- Designed For
- Apple iPhone 11 Pro Max
- Material
- Polycarbonate
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Shockproof, scratch-resistant, drop-proof
- Cover Type
- Back cover
- Max Height of Shock Resistance
- 4.57 m
- 1 year
- Designed For
