Griffin Survivor Extreme for iPhone 11 Pro - Black/Gray/Smoke
Quicklinx: FHTZWS00 Mfr#: GIP-029-BKG
Get out there. Rain, mud, drops, whatever you're into, Survivor Extreme for iPhone is built to survive. Survivor Extreme is the peak of all-conditions protection.
  • Protects your phone when the going gets messy
    Survivor Extreme's sealed-shell design is engineered to give your iPhone an IP-55 rating against mud, water and debris to prevent scratches and damage to your phone's body and screen. Your iPhones speakers and microphones are sealed with water-resistant membranes to keep you in touch no matter how sloppy things get.
  • Easy-install slide-on screen prevents screen damage
    Extreme's easy-on sliding screen protector guards your iPhone's multi-touch display from smudges, scratches and more. And it's fully compatible with your Touch ID scanner.
  • Durable, ready-for anything belt clip
    Extreme's rugged locking clip carries your iPhone clipped on to your waist or a backpack strap. The rotating clip locks open to position your phone perfectly whenever you want to watch videos or make calls on FaceTime.
Griffin Survivor Extreme - back cover for mobile phone
Back cover for mobile phone
Material
Polycarbonate
Grey, black, smoke
1-year warranty
Apple iPhone 11 Pro
Material
Polycarbonate
Grey, black, smoke
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Shockproof, scratch-resistant, drop-proof
Cover Type
Back cover
Max Height of Shock Resistance
4.57 m
1 year
Apple iPhone 11 Pro
