Griffin Survivor All-Terrain for Apple 9.7-inch iPad (5th generation, 6th generation)
Quicklinx: FM9YWS00 Mfr#: GB43626
Designed to meet or exceed US Department of Defense MIL-STD-810G, Survivor All-Terrain protects your iPad from 8-foot (2.4-meter) drops onto concrete. Inside Survivor All-Terrain's hard shell, the proprietary Impact Dispersion System surrounds your iPad with a silicone ring that absorbs and directs impact forces away from the device.
  • 8-foot drop protection
  • Rain, mud, sand, snow, and dust protection
    You probably want to be able to use your iPad anywhere. That's why Survivor All-Terrain is completely sealed to keep out dust, sand, rain, and a host of other environmental factors.
  • 4 layers of protection, one incredible case
    Survivor All-Terrain's 4 layers of protection start with a shatter-resistant polycarbonate frame surrounded by a rugged, shock-absorbing bumper. The HD clarity screen protector snaps on to seal your touchscreen from the outside environment. Volume, power and mute switches are covered. And hinged plugs seal the dock connector and headphone port when you're not using them.
  • Full function, no compromises
    Survivor All-Terrain surrounds your iPad in protection, but never gets in your iPad's way. Water-proof speaker ports ensure that the speakers sound great. The screen shield is totally compatible with your iPad's Touch ID sensor and 3D Touch. And a fully-redesigned clip-on workstand is included; it's perfect for positioning your iPad for watching videos or typing.
Griffin Survivor All-Terrain - protective case for tablet
Protective case for tablet
Screen Size Compatibility
9.7"
Material
Silicone, polycarbonate, PET
Purple
1-year warranty
Rugged
Material
Purple
Carrying Case
Protective case
Recommended Use
For tablet
9.7"
Protection
Shockproof, dust-resistant, dirt-resistant, impact protection, smudge-proof, shatterproof, sandproof, drop-proof, snowproof, rainproof
Screen protector, stand
MIL-STD 810G
1 year
