Griffin Screen Care for Galaxy S8 Clear
Quicklinx: D6T9WS00 Mfr#: GB43572
Use only high-clarity, ultra-hard tempered glass to protect your phone's screen. The glass is 9H scratch-resistance tested, so it's ready to stand up to your keys, tabletops, sand, and other abrasive conditions. At just. 33 mm thin, Survivor Glass goes on easy and practically disappears, so it works with most open-faced cases. Survivor Glass is kiln finished to follow your Galaxy S8's dual curved-edge Infinity display. No more edges to spoil the view.
  • Hardened defenses
  • Out on the edge
  • Shine on
    Micro-polishing brings Survivor Glass to a mirror finish that never gets in the way of your Galaxy's touchscreen, so your movies and pictures look great. A micron-thin anti-oil coating keeps fingerprints and oils from spoiling the view.
  • Easy-on installation
    Just wipe down your phone's screen with the included no-lint polishing cloth, align the glass, and press it gently into place. Survivor Glass uses a high-quality, micro-suction adhesive to adhere bubble-free to your phone's screen.
Griffin Survivor - screen protector for mobile phone
Screen protector - glass
Intended For
Mobile phone
Protection
Scratch-resistant, dirt-resistant
Product Material
Tempered glass (9H)
Thickness
0.33 mm
1-year warranty
Samsung Galaxy S8
Intended For
Mobile phone
Protection
Product Material
Tempered glass (9H)
Thickness
0.33 mm
1 year
Samsung Galaxy S8
