Product
Griffin Screen Care for GALAXY S8+, Clear
Quicklinx: D6TCWS00 Mfr#: GB43573
£15.28 ex VAT
£18.33 inc VAT
Save your Galaxy S8's touchscreen from scratches, dirt, oils, and smudging with Survivor Glass Screen Protectors.
  • Hardened defenses
    They use only high-clarity, ultra-hard tempered glass to protect your phone's screen. The glass is 9H scratch-resistance tested, so it's ready to stand up to your keys, tabletops, sand, and other abrasive conditions. At just. 33 mm thin, Survivor Glass goes on easy and practically disappears, so it works with most open-faced cases.
  • Out on the edge
    Survivor Glass is kiln finished to follow your Galaxy S8+'s dual curved-edge Infinity display. No more edges to spoil the view.
  • Shine on
    Micro-polishing brings Survivor Glass to a mirror finish that never gets in the way of your Galaxy's touchscreen, so your movies and pictures look great. A micron-thin anti-oil coating keeps fingerprints and oils from spoiling the view.
  • They brought in reinforcements
    Survivor Glass' edges are reinforced to prevent micro-cracks that occur from everyday use, You can't see those cracks, but they can compromise the internal integrity of the glass itself and lead to early failure.
  • Easy-on installation
    Just wipe down your phone's screen with the included no-lint polishing cloth, align the glass, and press it gently into place. Survivor Glass uses a high-quality, micro-suction adhesive to adhere bubble-free to your phone's screen.
Griffin Survivor - screen protector
Screen protector
Intended for
Mobile phone
Protection
Scratch-resistant, dirt-resistant
Product Material
Tempered glass (9H)
Thickness
0.33 mm
1 year warranty
Samsung Galaxy S8+
Screen protector
Intended for
Mobile phone
Protection
Product Material
Tempered glass (9H)
Thickness
0.33 mm
1 year
Samsung Galaxy S8+
Brand: Griffin
Price Range Ex VAT: 0 - 50
