Griffin Retractable Lightning Cable
Quicklinx: 9YRKWS00 Mfr#: GC37871
Compact, always-ready, and tangle-free, Griffin's retractable USB cable for Apple's Lightning cable-equipped devices is a must-have.
In your bag, pack, or pocket, it measures less than 2 inches wide by half an inch thick, and just under 4 inches from connector tip to connector tip. But pull out the spring-loaded cable and you have a full 27 inches of tangle-resistant USB to Lightning connection for charging and syncing your iPod, iPad or iPhone. Use with any USB home or car charger, or with your computer. The internal ratchet mechanism locks the cable at the length you need; a quick tug on it releases the ratchet.
Griffin Lightning cable - 68.6 cm
Cable
Lightning cable
Length
68.6 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Retractable
Cable Type
Lightning cable retractable
Length
68.6 cm
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
