Engineered with a smooth, packable form, this Power Bank easily fits into your on-the-go lifestyle, whether it's being slipped into your bag, backpack or luggage. With 10,000 mAh, you can give your smartphone, wearable or tablet the 100% power boost it needs before (or when) it hits 0% - perfect for a weekend away. In fact, the 12W USB-A outputs power that's more than 2x faster than most standard wall chargers that come in-box with your device. And the additional 5W USB-A port lets you conveniently charge two devices at the same time. When the Power Bank itself runs low on juice, you can effortlessly recharge it using the included micro-USB cable. Plus, the built-in LED power gauge shows the battery's charge capacity with just a quick push of the power button.
- Griffin Reserve power bank - 2 x USB - 17 Watt
- Product Type
- Power bank
- Black
- Output Connector Type
- Total 2: 2 x USB - on cable: Micro-USB
- Voltage Provided
- 5 V
- Max Electric Current
- 2.4 A
- Battery
- 10000 mAh
- Power Provided
- 17 Watt
- Power Device Details
- - 4 pin USB Type A - 5 V - 12 W - 2.4 A , - 4 pin USB Type A - 5 V - 5 W - 1 A
- Cables
- Micro-USB cable
- 1-year warranty
- Product Type
- Power bank
- Designed For
- Mobile phone
- Enclosure Colour
- Black
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 2 x 4 pin USB Type A
- Power Provided
- 17 Watt
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.4 A
- 4 pin USB Type A - 5 V - 12 W - 2.4 A , 4 pin USB Type A - 5 V - 5 W - 1 A
- LED indicator
- Capacity
- 10000 mAh
- Cables Included
- Micro-USB cable
- Limited warranty - 1 year
Griffin Reserve 10,000 mAh Power Bank - Black
