A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
- Griffin AirStrap 360 - back cover for tablet
- Product Type
- Back cover for tablet
- Screen Size Compatibility
- 9.7"
- Material
- Neoprene, polycarbonate, thermoplastic polyurethane (TPU)
- Black
- 1 year warranty
- Designed For
- Apple 9.7-inch iPad (5th generation); 9.7-inch iPad Pro
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Scratch-resistant, drop-proof
- Cover Type
- Back cover
- Carrying Strap
- Hand strap
- Max Height of Shock Resistance
- 0.8 m
- 1 year
- Designed For
- Apple 9.7-inch iPad (5th generation) , Apple 9.7-inch iPad Pro
