A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
- Griffin AirStrap 360 - back cover for tablet
- Product Type
- Back cover for tablet
- Black
- 1-year warranty
- Designed For
- Apple iPad mini 5 (5th generation)
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Impact protection
- Cover Type
- Back cover
- Carrying Strap
- Hand strap
- Replace or repair - 1 year
- Designed For
