Griffin AirStrap 360 10.5" Back Cover for iPad - Black
Quicklinx: FPZZWS00 Mfr#: GB43579
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Griffin AirStrap 360 - back cover for tablet
Back cover for tablet
Screen Size Compatibility
10.5"
Material
Neoprene, polycarbonate, thermoplastic polyurethane (TPU)
1-year warranty
Material
Carrying Case
Protective cover
Recommended Use
For tablet
10.5"
Protection
Shockproof, drop-proof
Cover Type
Back cover
Carrying Strap
Hand strap
Max Height of Shock Resistance
80 cm
1 year
