Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
GoPro Ultra Wide Lens Mod
Quicklinx: HXQXWS00 Mfr#: AEWAL-001
£83.33 ex VAT
£99.99 inc VAT
Transform HERO13 Black into the ultimate POV camera by capturing more in every shot with the highest level of video stabilisation. The premium HB-Series Ultra-Wide Lens Mod dramatically expands HERO13 Black’s field of view (FOV) to 177°—36% wider and 48% taller than shots captured with its standard lens.1 It also maximises HyperSmooth performance for unbreakable in-camera video stabilisation with resolution all the way up to 4K60. Recording in the new 1:1 aspect ratio gives you the freedom to crop your footage to widescreen 16:9 or vertical 9:16 shots. HERO13 Black detects the lens and automatically adjusts its settings accordingly—no other setup needed. Durable and scratch-resistant, the lens is completely waterproof2 when installed and ready to capture immersive shake-free footage of your adventures.
1 36% wider compared to HERO13 Black recording 16:9 aspect ratio footage with the Wide digital lens vs. HERO13 Black with the Ultra-Wide Lens Mod using the Ultra-Wide digital lens. 48% taller compared to HERO13 Black recording 9:16 aspect ratio footage with the Wide digital lens vs. HERO13 Black with the Ultra-Wide Lens Mod using the Ultra-Wide digital lens.
2 Ultra-Wide Lens Mod is not intended for use under water.
What’s Included
  • Ultra-Wide Lens Mod
  • Front and Rear Protective Caps
  • Microfibre Lens Cloth
  • Enhanced field of view
    The wide angle capability of 177 degrees allows for capturing expansive landscapes and immersive action shots, ensuring no detail is missed.
  • Durable underwater performance
    Designed for underwater use, this lens can withstand varied conditions, making it excellent for snorkelling and diving excursions.
  • Automated integration
    The auto lens identification feature simplifies setup, automatically adjusting to enhance shooting convenience.
  • Advanced lens coatings
    Hydrophobic and scratch-resistant coatings ensure the lens remains functional and clear, protecting against scratches and water interference.
Brand: GoPro
