Expand the creative possibilities of your HERO13 Black with incredible up-close capture options. The premium HB-Series Macro Lens Mod gets you 3x closer to your subject than ever before on a GoPro, helping you capture slo-mo B-roll shots of muddy mountain bike spokes or a time lapse of a flower blooming. The variable focus ring lets you manually adjust the focus distance from 10 cm to 0.6 m, while focus peaking helps you to see what’s in focus on the camera screen. Your camera detects the lens when it’s attached and automatically adjusts its settings accordingly—no other setup needed. Built durable, scratch resistant, water repellent and waterproof1 when installed, it can go just about anywhere.
1 Macro Lens Mod is not intended for use under water.
What’s Included
- Macro Lens Mod
- Front and Rear Protective Caps
- Microfibre Lens Cloth
