GoPro HERO13 Black Creator Edition
Quicklinx: HXQDWS00 Mfr#: CHDFB-131-EU
Select:
£499.17 ex VAT
£599.00 inc VAT
The HERO13 Black Creator Edition is an all-in-one content capturing powerhouse that makes vlogging, filmmaking and live streaming easier than ever. It’s built around HERO13 Black with best-in-class 5.3K60 video and award-winning HyperSmooth 6.0 video stabilization. It’s attached to a versatile battery grip that delivers over 5 hours of 4K recording time per charge1 and has built-in buttons that let you comfortably control the camera during long shoots. This complete system features a directional microphone that reduces ambient noise, Bluetooth audio for use with your wireless mic, an LED light, a Magnetic Latch Mount that makes easier than ever to swap batteries and multiple options for transferring footage-including wireless, wired and with your SD card.2It’s also compatible with the HB-Series Lenses2 that let you expand your capture capabilities to include ultra-wide shots, pro-quality anamorphic footage, close than-ever shots and motion blur effects using neutral density filters.
What’s Included
HERO13 Black Camera
  • Carrying Case
  • Enduro Battery
  • Curved Adhesive Mount
  • Mounting Buckle + Thumb Screw
  • USB-C Cable
Volta (Battery Grip / Tripod / Remote)
  • USB Pass-Through Door
  • Thumb Screw
  • Lanyard
Media Mod
  • Removable Windscreen
  • Vertical Mounting Buckle
Light Mod
  • Light Diffuser
  • 2-Finger Adapter
  • Thumb Screw
1 Runtime measured at a temperature of 77°F (25°C) with a wind speed of 0.6m/sec with the Wide digital lens; wireless connections, Bluetooth® and HyperSmooth on; front and rear LCD screens on with a 1-minute screensaver; voice control and GPS off.
2 Sold separately.
  • Versatile mounting options
    The GoPro HERO13 Black is mountable, making it easy to attach to various surfaces and capture engaging footage from unique angles.
  • High-definition video recording
    Achieve high-definition video support with resolutions up to 5.3K and frame rates reaching 240 fps for smooth, dynamic playback.
  • Advanced image stabilization
    Equipped with HyperSmooth 6.0 electronic image stabilization, this camera ensures smooth and steady video, even during high-action scenarios.
  • Comprehensive shooting programs
    Various shooting programs like night mode, burst mode, and multiple white balance presets offer flexibility for different environments and creative expressions.
  • Multi-functional connectivity
    The camera supports wireless video and image uploads to cloud servers, along with USB Type-C connectivity for streamlined data transfer.
GoPro HERO13 Black - Creator Edition - action camera
Action camera - 5.3K
Action Camera Type
Mountable
Intelligent Assistant
Direct
Memory Card Slot
microSD card
Image Processor
GP2
Wireless Interface
Wi-Fi, Bluetooth 5.3 LE
Sensor Resolution
27.6 MP
Effective Sensor Resolution
Photo: 27.13 MP
Lens System
Wide-angle lens 12 - 39 mm - f/2.5
Focus Adjustment
Focus free
Image Stabiliser
Electronic (HyperSmooth 6.0)
Display
LCD display - 2.27"
Display (2nd)
LCD display - 1.4" - colour
Supported Battery
1900 mAh (included)
USB-C
7.18 cm x 3.36 cm x 5.08 cm
125 g
Camcorder Sensor Resolution
27.6 MP
Effective Photo Resolution
27.13 MP
Optical Sensor Type
CMOS
Optical Sensor Size
1/1.9"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
6400
Native ISO
100-6400
Image Processor
GP2
Image Stabiliser
HDR Mode
SuperPhoto + HDR
Digital Video Format
H.265, HEVC
Image Recording Format
RAW, JPEG
Audio Signal Format
WAV
USB-C, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3 LE
Connectivity Features
Live streaming (1080p), wireless video upload to cloud server, wireless image upload to cloud server
Exposure & White Balance
Shooting Programs
Burst mode, night mode, sunrise, sunset, dawn, dusk, twilight mode
Special Effects
Vibrant, Flat, natural, Star trails, Light painting, vehicle light trails
White Balance
Automatic, presets
White Balance Presets
Native, 2300K, 2800K, 3200K, 4000K, 4500K, 5000K, 5500K, 6000K, 6500K
Max Shutter Speed
1/2000 sec
Exposure Compensation
±2 EV range
Lens System
Wide-angle lens 12 - 39 mm - f/2.5 - wide angle
Focus Adjustment
Focus free
Additional Features
Continuous Shooting Speed
6 frames per second, 10 frames per second, 5 frames per second, 3.3 frames per second, 3 frames per second, 30 frames per second
Self-Timer Delay
3sec, 10 sec
Low Lux / Night Mode
Additional Features
HDR image enhancement technology, horizon leveling, horizon lock, HindSight, duration capture, schedule recording in power-off mode, time code, built-in speaker, Dual LCD screens, auto boost, voice control, PC webcam option, interval shooting mode, Protune support, multi-picture burst, built-in 3 microphones, denoise
Action Camera Features
Camera Type
Mountable
TimeWarp video recording, Loop recording, Time-Lapse video recording, Night lapse video recording
Tripod Mount
Connection Point
1/4" screw & GoPro
Display
2.27" LCD display
Display Form Factor
Built-in
Touch Screen
Camera Display (2nd)
LCD display
Diagonal Size
1.4 in
Colour Support
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB (USB Type-C)
Internet of Things (IoT)
Voice Controlled
Direct
Lens cover, shooting grip / mini tripod / selfie stick, media mod, LED light, additional battery, magnetic mount, curved adhesive mount, carrying case, wind screen, USB adapter, diffuser, cold shoe mount adapter, lanyard, thumb screw, thumb screw (short), USB-C cable, 4 stickers
Protection
Waterproof
Underwater Depth
Up to 10 m
Battery Type
GoPro Enduro
Details
1900 mAh (included)
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card
Memory Card Included
No
Image Storage
5568 x 4872
Video Capture
5312 x 2988 - 24 - 60 fps , 5312 x 4648 - 24 - 30 fps , 3840 x 2160 - 24 - 120 fps , 3840 x 3360 - 25 - 60 fps , 2704 x 1520 - 240 fps , 2704 x 2028 - 120 fps , 1920 x 1080 - 25 - 240 fps
7.18 cm
3.36 cm
5.08 cm
125 g
Weight Details
Camera only: 125 g , Camera with battery and mounting fingers: 159 g
-10 °C
35 °C
HXQD GoPro Dual Battery Charger (HERO13 Black) In Stock £66.66
HXQD GoPro Contacto In Stock £66.66
HXQD GoPro Macro Lens Mod In Stock £108.33
Brand: GoPro
