Tiny by design and easy to use, our smallest 4K camera features a rugged super light design that’s a fraction of the size and weight of other GoPro cameras, but still waterproof to 5 m. Streamlined controls let you record 4K video, immersive photos and slo-mo shots with a press of the Shutter button. After recording, play back your video on the GoPro Quik app. HyperSmooth video stabilisation will automatically smooth out the shakes in your footage. Plug HERO in to charge and your footage will be uploaded to the cloud, turned into a highlight video and sent to your phone so you can relive your adventure and share the fun.1
What’s Included
- HERO Camera
- Curved Adhesive Mount
- Mounting Buckle + Thumb Screw
- USB C-C Cable
1Within your home Wi-Fi network. GoPro subscription required. GoPro subscription available in selected territories. Cancel anytime. Visit gopro.com for info and availability
Stunning video quality
HERO captures gorgeous video. Relive your most memorable or incredible moments in stunning quality. Easily create a video using GoPro Studio software, then share it with your friends and family on Facebook, YouTube and more. -
Choose from a variety of photo modes to get the perfect shot
Capture 5MP still photos, or use burst mode to capture up to 3 frames in one second for a unique photo sequence. Time Lapse mode automatically captures photos at set time intervals from 0.5 to 60 seconds. It's great for gear-mounted shots when the shutter button is out of reach, or capturing a series of photos so you can pick your favorites. -
Ultra wide-angle glass lens
Fit more in every frame thanks to HERO ultra-wide-angle glass lens. It's great for gear-mounted shots and close-range selfies - and delivers an immersive perspective for uniquely engaging footage. -
Waterproof and durable
HERO rugged housing is waterproof to, and protects the camera in wet, dirty or sandy environments. Built tough to withstand almost anything you can throw at it, you can take HERO nearly anywhere to capture life as it happens. -
High-performance audio
HERO features excellent audio performance, capturing even the most subtle of sounds - whether you're recording voices, music or the roar of your engine on a spirited drive. Advanced wind-noise reduction technology keeps the audio clearer during high-speed activities. The included Skeleton Backdoor enables enhanced audio capture during low-speed activities in dry, dirt-free environments. -
Small and lightweight
The HERO camera is super small, ultra-portable and perfect for low-profile mounting. Its compact design means you can comfortably wear it or mount it to your gear as you capture your favorite activities, or slip it in your pocket or bag to take anywhere.
- GoPro HERO - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wi-Fi, Bluetooth
- Effective Sensor Resolution
- Photo: 12.0 MP
- Lens System
- Wide-angle lens f/2.3
- Focus Adjustment
- Focus free
- Display
- LCD display - 1.76"
- Supported Battery
- 1255 mAh (included)
- Interface
- USB-C
- 5.66 cm x 2.94 cm x 4.77 cm
- 86 g
- 2-year warranty
- Product Type
- Effective Photo Resolution
- 12.0 MP
- Frame Rate (Max Resolution)
- 30 fps
- Digital Video Format
- H.265, HEVC
- Image Recording Format
- JPEG
- Interface
- USB-C, IEEE 802.11a/b/g/n/ac, Bluetooth 5.2 LE
Lens System
- Wide-angle lens f/2.3 - wide angle
- Focal Length Equivalent to 35mm Camera
- 15mm
- Focus Adjustment
- Focus free
Additional Features
- Additional Features
- HDR image enhancement technology, 8-bit colour depth
Action Camera Features
- Camera Type
- Mountable
Tripod Mount
- Connection Point
- GoPro
Display
- 1.76" LCD display
- Display Form Factor
- Built-in
- Touch Screen
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB (USB Type-C)
- Included Accessories
- Curved adhesive mount, mounting buckle, thumb screw, 2 stickers, USB-C cable
- Protection
- Waterproof
- Underwater Depth
- Up to 5 m
- Battery Type
- Integrated
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card
- Memory Card Included
- No
- Video Capture
- 3840 x 2160 - 25 - 30 fps , 1920 x 1080 - 25 - 30 fps , 2704 x 1520 - 50 - 60 fps
- Limited warranty - 2 years
- 5.66 cm
- 2.94 cm
- 4.77 cm
- 86 g
- -10 °C
- 35 °C
GoPro Adventure Kit 3.0 | In Stock | £49.99 |
GoPro Chesty (Performance Chest Mount) | In Stock | £33.33 |
