GoPro HERO
Quicklinx: HXQPWS00 Mfr#: CHDHF-131-EU
26 In Stock
£165.84 ex VAT
£199.00 inc VAT
Tiny by design and easy to use, our smallest 4K camera features a rugged super light design that’s a fraction of the size and weight of other GoPro cameras, but still waterproof to 5 m. Streamlined controls let you record 4K video, immersive photos and slo-mo shots with a press of the Shutter button. After recording, play back your video on the GoPro Quik app. HyperSmooth video stabilisation will automatically smooth out the shakes in your footage. Plug HERO in to charge and your footage will be uploaded to the cloud, turned into a highlight video and sent to your phone so you can relive your adventure and share the fun.1
What’s Included
  • HERO Camera
  • Curved Adhesive Mount
  • Mounting Buckle + Thumb Screw
  • USB C-C Cable
1Within your home Wi-Fi network. GoPro subscription required. GoPro subscription available in selected territories. Cancel anytime. Visit gopro.com for info and availability
  • Stunning video quality
    HERO captures gorgeous video. Relive your most memorable or incredible moments in stunning quality. Easily create a video using GoPro Studio software, then share it with your friends and family on Facebook, YouTube and more.
  • Choose from a variety of photo modes to get the perfect shot
    Capture 5MP still photos, or use burst mode to capture up to 3 frames in one second for a unique photo sequence. Time Lapse mode automatically captures photos at set time intervals from 0.5 to 60 seconds. It's great for gear-mounted shots when the shutter button is out of reach, or capturing a series of photos so you can pick your favorites.
  • Ultra wide-angle glass lens
    Fit more in every frame thanks to HERO ultra-wide-angle glass lens. It's great for gear-mounted shots and close-range selfies - and delivers an immersive perspective for uniquely engaging footage.
  • Waterproof and durable
    HERO rugged housing is waterproof to, and protects the camera in wet, dirty or sandy environments. Built tough to withstand almost anything you can throw at it, you can take HERO nearly anywhere to capture life as it happens.
  • High-performance audio
    HERO features excellent audio performance, capturing even the most subtle of sounds - whether you're recording voices, music or the roar of your engine on a spirited drive. Advanced wind-noise reduction technology keeps the audio clearer during high-speed activities. The included Skeleton Backdoor enables enhanced audio capture during low-speed activities in dry, dirt-free environments.
  • Small and lightweight
    The HERO camera is super small, ultra-portable and perfect for low-profile mounting. Its compact design means you can comfortably wear it or mount it to your gear as you capture your favorite activities, or slip it in your pocket or bag to take anywhere.
GoPro HERO - action camera
Action camera - 4K
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi, Bluetooth
Effective Sensor Resolution
Photo: 12.0 MP
Lens System
Wide-angle lens f/2.3
Focus Adjustment
Focus free
Display
LCD display - 1.76"
Supported Battery
1255 mAh (included)
USB-C
5.66 cm x 2.94 cm x 4.77 cm
86 g
Action camera - 4K
Effective Photo Resolution
12.0 MP
Frame Rate (Max Resolution)
30 fps
Digital Video Format
H.265, HEVC
Image Recording Format
JPEG
USB-C, IEEE 802.11a/b/g/n/ac, Bluetooth 5.2 LE
Lens System
Wide-angle lens f/2.3 - wide angle
Focal Length Equivalent to 35mm Camera
15mm
Focus Adjustment
Focus free
Additional Features
Additional Features
HDR image enhancement technology, 8-bit colour depth
Action Camera Features
Camera Type
Mountable
Tripod Mount
Connection Point
GoPro
Display
1.76" LCD display
Display Form Factor
Built-in
Touch Screen
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB (USB Type-C)
Curved adhesive mount, mounting buckle, thumb screw, 2 stickers, USB-C cable
Protection
Waterproof
Underwater Depth
Up to 5 m
Battery Type
Integrated
Details
1255 mAh (included)
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card
Memory Card Included
No
Video Capture
3840 x 2160 - 25 - 30 fps , 1920 x 1080 - 25 - 30 fps , 2704 x 1520 - 50 - 60 fps
5.66 cm
2.94 cm
4.77 cm
86 g
-10 °C
35 °C
Brand: GoPro
