GoPro Extension Pole + Waterproof Shutter Remote
Quicklinx: HXQYWS00 Mfr#: AGXTS-002-ES
£66.66 ex VAT
£79.99 inc VAT
The action is closer and the travel is lighter with the Extension Pole + Waterproof Shutter Remote. Stretching to 122 cm and collapsing to 25 cm, this extension pole reaches longer and collapses smaller than its predecessor, El Grande. A detachable wireless remote makes it easy to take photos and start/stop recording when the pole is extended and your GoPro is out of reach. The pole is crafted from durable lightweight aluminium and is waterproof so you can capture your favourite activities in wet or dry conditions. The ball joint adapter easily attaches to the extension pole using a 1/4-20 mount to provide full camera rotation and tilt for maximum capture flexibility. The anti-slip grip and wrist lanyard keep the pole securely in your hand during your adventure.
1Bluetooth connectivity in Waterproof Shutter Remote is not functional under water.
What’s Included
  • Extension Pole
  • Waterproof Shutter Remote
  • Remote Strap
  • Mounting Finger Adapter
  • Ball Joint Adapter + Mounting Base
  • Wrist Lanyard
  • Thumb Screw
Brand: GoPro
