This Dual Battery Charger conveniently charges 2 batteries dynamically to give you a fully charged battery as soon as possible1 so you can keep adventuring. Quick-check status lights let you know the batteries’ charge status even when you’re not plugged into power. Comes with 2 high-performance Enduro batteries that you can use as replacements or spares for HERO13 Black.
What’s Included
- Dual Battery Charger
- 2 Enduro Batteries for HERO13 Black
- USB C-C Cable
Efficient charging capability
This battery charger has a capacity of 1900 mAh, ensuring efficient and reliable charging for your action camera batteries. -
Dual charging ports
With two output connectors, it allows for the simultaneous charging of two batteries, maximizing convenience and saving time. -
Status indicators
The charger includes two LED indicators that provide clear feedback on the charging status, keeping you informed at all times. -
Temperature resistant design
Constructed to withstand low temperatures, this charger ensures consistent performance and reliability even in harsh weather conditions. -
Compatible with action cameras
Engineered for action cameras, making it an essential accessory for enthusiasts who need dependable power solutions.
- GoPro battery charger - with battery
- Product Type
- Battery charger + battery
- Designed For
- Action camera
- Output Connector Type
- Total 2
- Battery
- 1900 mAh
- Cables
- USB-C cable
- Supported Battery
- 2
- Limited lifetime warranty
- Designed For
- HERO13 Black
- Product Type
- Battery charger battery
- Designed For
- Action camera
- Output connectors
- Total 2
- Low temperature resistant, 2 LED indicators
- Capacity
- 1900 mAh
- Run Time (Up To)
- 2.5 hour(s)
Supported Battery
- Max Supported Qty
- 2
- Cables Included
- USB-C cable
- Limited warranty - lifetime
- Designed For
- GoPro HERO13 Black
GoPro Dual Battery Charger (HERO13 Black)
