GoPro Dual Battery Charger (HERO13 Black)
Quicklinx: HXQQWS00 Mfr#: AEDBD-201-EU
10 In Stock
£66.66 ex VAT
£79.99 inc VAT
This Dual Battery Charger conveniently charges 2 batteries dynamically to give you a fully charged battery as soon as possible1 so you can keep adventuring. Quick-check status lights let you know the batteries’ charge status even when you’re not plugged into power. Comes with 2 high-performance Enduro batteries that you can use as replacements or spares for HERO13 Black.
What’s Included
  • Dual Battery Charger
  • 2 Enduro Batteries for HERO13 Black
  • USB C-C Cable
  • Efficient charging capability
    This battery charger has a capacity of 1900 mAh, ensuring efficient and reliable charging for your action camera batteries.
  • Dual charging ports
    With two output connectors, it allows for the simultaneous charging of two batteries, maximizing convenience and saving time.
  • Status indicators
    The charger includes two LED indicators that provide clear feedback on the charging status, keeping you informed at all times.
  • Temperature resistant design
    Constructed to withstand low temperatures, this charger ensures consistent performance and reliability even in harsh weather conditions.
  • Compatible with action cameras
    Engineered for action cameras, making it an essential accessory for enthusiasts who need dependable power solutions.
GoPro battery charger - with battery
Battery charger + battery
Action camera
Output Connector Type
Total 2
1900 mAh
Cables
USB-C cable
Supported Battery
2
HERO13 Black
Battery charger battery
Action camera
Output connectors
Total 2
Low temperature resistant, 2 LED indicators
1900 mAh
Run Time (Up To)
2.5 hour(s)
Supported Battery
Max Supported Qty
2
USB-C cable
Limited warranty - lifetime
GoPro HERO13 Black
Brand: GoPro
