Google Wifi (2021)
Google Wifi (2021)
Quicklinx: GK3XWS00 Mfr#: GA02430-GB
  • IEEE 802.11n
£74.17 ex VAT
£89.00 inc VAT
Google Wifi is a scalable and flexible connected Wi-Fi system that replaces your existing router to help provide a consistently strong signal.
The Google WiFi points can be multiplied as needed, to cover every inch of your home with a reliable WiFi mesh to ensure you never lose your connection. Each Google WiFi point will work seamlessly together – passing you to the best connection as you move around the house.
A smart buy for whole home coverage
Get a high performance mesh system without spending a lot. From video calling to watching 4k videos and gaming, Google Wifi helps you get the most out of your favourite streaming services and connected devices.
Coverage in your whole home.
Helps blanket your home in fast, reliable Wi-Fi and helps reduce buffering in every room.
Simple setup in a few steps.
Use the Google Home app to create your network and get online in minutes.
Control at your fingertips.
Manage and control your network from anywhere with your phone.
Part of Google Home
The Google WiFi will fit right into your smart household. With the Google Home app, setting up and managing your network will be straightforward and intuitive. No need for an tech expert here.
You can set up guest networks, manage your kids' access and more. And you can do that even with voice commands, using your smart speakers.
Reliable security
Featuring sophisticated hardware and cloud-based security, Google WiFi automatically updates itself to keep you and your personal data secure.
  • Home Wi-Fi, simply solved
    Enjoy a fast signal in every room, on every device. Google Wi-Fi is an advanced type of connected system that replaces your router for seamless coverage throughout your home.
  • Your entire home is covered
    Do everything you love online, anywhere in your house. Google Wi-Fi was designed to handle multiple devices streaming, downloading, and sharing at the same time.
  • Keeps itself fast
    Network Assist is intelligent software built into Google Wi-Fi to provide you with fast speed. Behind the scenes, Network Assist automatically helps you avoid Wi-Fi congestion, and transitions you to the closest Wi-Fi point for great signal.
  • Speed coach
    Network Assist will offer suggestions on how to optimize performance, like where to move a Google Wi-Fi point for faster speeds or providing data so you can adjust your ISP plan.
Google Wifi - wireless router - Bluetooth, 802.11a/b/g/n/ac - desktop
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Wireless extender mode
White
10.61 cm x 10.61 cm x 6.87 cm
340 g
Android 4.0 or later, Apple iOS 8 or later
2-year Limited Warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2-PSK
1 x ARM 710 MHz
RAM
512 MB
Flash Memory
4 GB
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter - 15 Watt
Installed Qty
3
9 Watt
Enclosure Colour
White
1 x network cable - 2 m
10.61 cm
10.61 cm
6.87 cm
340 g
Brand: Google
