Google Pixelbook Go Core i7 16GB 256GB 13.3" Touch Chrome OS
Quicklinx: FWF3WS00 Mfr#: GA00526-UK
  • Core i7
  • IEEE 802.11n
Ultra-thin, lightweight, a powerful processor, and up to 12 hours of battery life. Pixelbook Go is ready to go when you are.
Good to go.
Pixelbook Go lets you stay unplugged for up to 12 hours, so you don’t need to carry a charger. And when you do need a charge, get up to 2 hours of use in just 20 minutes so you can keep going.
Made to move.
Pixelbook Go is lightweight – barely 2 pounds. It’s 13 mm thin with a grippable design, making it easier to carry.
Get it done. Fast.
Pixelbook Go starts up in seconds, and makes working a breeze. The 8th Gen Intel® Core™ processor is built for speed and responsiveness, powering everything you do. And when you need quick help, just ask Google.
Go without worry.
Pixelbook Go is designed to prevent things from getting off track. The Titan™ C security chip and built-in anti-virus software help protect your data. And Chrome OS updates automatically, always giving you the latest features and security.
Ready to entertain.
With up to 8.3 million pixels and dual stereo speakers, you get amazing picture and sound for watching movies, editing photos, or video chatting.
  • Grippable design
    Textured bottom makes it easier to carry.
  • Charge in minutes
    Get up to 2 hours of battery use in just 20 minutes of charge.
  • Starts fast
    Starts up in seconds so it's ready when you are.
  • Goes fast
    The Intel Core processor is quick and responsive.
  • Brilliant 13.3" touchscreen display
    High definition picture with up to 4K display.
  • High-resolution Duo Cam
    1080p webcam makes video chatting feel like you're there.
  • Dual, front-firing speakers
    Whether you're watching your favourite movie or listening to your favourite song, enjoy stereo-quality sound.
  • Quiet and comfortable
    Minimise noise disruption with Hush Keys. And with the backlit keyboard, you can do more from anywhere, even in the dark.
  • Keep your data protected
    The Titan C security chip ensures your information, passwords, and operating system are protected on your Pixelbook Go.
Google Pixelbook Go - 13.3" - Intel Core i7 - 16 GB RAM - 256 GB SSD
Chromebook
Operating System
Chrome OS
Intel Core i7
16 GB
Storage
256 GB SSD
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 12 hours
Ambient light sensor, magnetometer
Security
Titan-C Security Chip
Just black
31.1 cm x 20.63 cm x 1.34 cm
1.061 kg
Region: United Kingdom
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Intel Core i7
RAM
16 GB
Storage
Main Storage
256 GB SSD
Display
13.3"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Colour Gamut
72% NTSC
72% NTSC colour gamut
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1080p
Resolution
2 Megapixel
Frame Rate
60 frames per second
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
47 Wh
Run Time
Up to 12 hours
AC Adapter
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
USB-C , Headphone output
Just black
Case Material
Magnesium alloy
Integrated Options
Security
Power adapter
USB-C charge cable
FIDO Certified
Localization
1.061 kg
Sustainability Information
TCO Certified
