Meet Google Pixel Buds Pro, the wireless earbuds with premium, immersive sound that adapts to you. Active Noise Cancellation with Silent Seal™ blocks outside sounds, so your music shines.
How premium sounds.
Meet Google Pixel Buds Pro, with premium Active Noise Cancellation for immersive sound.
Immersive, premium sound.
Active Noise Cancellation adapts to your ear.
Pixel Buds Pro use Silent Seal™ to adapt to your ear and maximize the level of outside noise being blocked.
Volume EQ brings out the details.
Volume EQ adjusts the tuning as you turn the volume up or down, so highs, mids, and lows consistently sound balanced at any level.
Transparency mode helps you hear what’s outside.
Lets you hear outside sounds in real time so you can be more aware of your surroundings, like when crossing the street.
Small buds built for big music.
Custom-designed 11 mm speaker drivers make music sound powerful, yet nuanced.
A fit made for you.
Even the eartips adapt to you.
The pliable eartips have a moldable design that conforms to the shape of your ear, creating a gentle seal for your music to shine.
No plugged-ear feeling.
Sensors actively measure the pressure in your ear canal so the earbuds can relieve it and stay comfortable.
Touch controls make it easy.
Control media and calls with a simple tap, swipe to adjust the volume level, and touch and hold for Active Noise Cancellation.
Automatically helpful.
Be heard clearly on calls.
Your voice sounds clear even in loud and windy places, thanks to beamforming mics, a voice accelerometer, and wind-blocking mesh covers.
Help is in your ear.
Ask Google to give you walking directions, respond to texts, get live translations, and more – completely hands-free so you can focus on what’s in front of you.
The battery keeps up with your life.
Get up to 11 hours of listening time, and a full 31 hours with the charging case.
Not afraid of water.
Pixel Buds Pro are water resistant, so you can wear them during sweaty workouts or on rainy days.
Pairs well with others.
From phone to laptop, just like that.
Easily go from music on your phone to video calls on your laptop. Multipoint connectivity helps you switch between compatible devices.
Works with iOS or Android.
Pixel Buds Pro pair quickly and easily with any Bluetooth® 4.0+ device, including phones, tablets, laptops, and smartwatches.
Charge wirelessly.
Pixel Buds Pro can charge wirelessly with Pixel Stand or other Qi-certified chargers.
Powered by a custom processor, custom algorithms, and custom speakers, Active Noise Cancellation uses Silent Seal to maximize the outside noise being blocked. -
Custom-designed 11 mm speaker drivers make music sound powerful, yet nuanced. A full 5-band EQ lets you customize the sound to your preferences. -
Volume EQ adjusts the tuning as you turn the volume up or down, so highs, mids, and lows consistently sound balanced at any level. -
Transparency mode helps you hear what's outside
Transparency mode lets you hear outside sounds in real time so you can be more aware of your surroundings, like when crossing the street. -
The pliable eartips have a moldable design that conforms to the shape of your ear, creating a gentle seal for your music to shine. -
Sensors actively measure the pressure in your ear canal so the earbuds can relieve it and stay comfortable. -
Control media and calls with a simple tap, swipe to adjust the volume level, and touch and hold for Active Noise Cancellation. -
Your voice sounds crystal clear even in loud and windy places, thanks to beamforming mics, a voice accelerometer, and wind-blocking mesh covers. -
Help in your ear
Ask Google to give you walking directions, respond to texts, get live translations, and more - completely hands-free so you can focus on what's in front of you. -
From phone to laptop just like that
Easily go from music on your phone to video calls on your laptop. Pixel Buds Pro use multipoint connectivity to help you automatically switch between devices. -
A battery that keeps up with your life
Get long-lasting listening time - up to dozens of hours with the charging case.
- Google Pixel Buds Pro - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Android phone, Android tablet
- Recommended Use
- Portable electronics
- Additional Functions
- Transparency mode
- Localisation
- United Kingdom
- Charcoal
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone Operation Mode
- Beamforming
- Microphones Included
- 6
- Controls
- Volume control, play/pause, answer call, ANC mode
- Intelligent Assistant
- Google Assistant
- Product Type
- True wireless earphones - Bluetooth - wireless
- Compatibility
- Transparency mode
- Dimensions & Weight Details
- Earbud: 2.203 cm x 2.233 cm x 2.372 cm / 6.2 g , Charging case with earphones: 5 cm x 2.5 cm x 6.32 cm / 62.4 g
- Charcoal
- Recommended Use
- Wind-blocking mesh covers, active in-ear pressure relief
- Protection
- Sweat-resistant, water-resistant
- Localisation
- United Kingdom
Audio Output
- In-ear
- Dynamic
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Equaliser
- 5-band
- Active Noise Cancelling Technology
- Google Silent Seal
- Diaphragm
- 11 mm
Microphone
- Form Factor
- Built-in
- Beamforming
- 6
Remote Control
- Controls
Tracking
- Sensors
- Proximity sensor, hall sensor, motion-detecting accelerometer, touch sensor, gyroscope, voice accelerometer
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Google Assistant
- Included Accessories
- 3 pairs of ear tips (small, medium, large), wireless charging case
- IEC 60529 IPX4, IPX2
- Battery
- Headphone battery rechargeable - wireless charging
- Wireless Charging Standards
- Qi
- Run Time Details
- Continuous playback (noise cancelling OFF): up to 11 hours , Continuous playback (noise cancelling OFF / with included charging case): up to 31 hours , Continuous playback (noise cancelling ON): up to 7 hours , Continuous playback (noise cancelling ON / with included charging case): up to 20 hours , Continuous playback (with 5 min charge / noise cancelling ON): up to 1 hour , Continuous playback (with 15 min charge / noise cancelling ON): up to 3 hours
