Pixel 9a
Magic made simple
Meet Pixel 9a – engineered by Google with more than you expect, for less than you think. Like Gemini built in to supercharge your productivity and creativity. A best-in-class camera for incredible photos. All-day battery and durable design.
Take the picture. And be in it, too.
Add Me makes sure no one is left out of a photo. Take one with the group, then swap in the photographer, and Pixel magically merges both photos.
It’s built to last.
Pixel 9a is designed to handle spills, dust, drops, and dings. From IP68 water and dust protection to a scratch-resistant display and long-lasting materials, it’s the most durable Pixel A-Series phone yet.
One ask, done across your apps.
Save time by asking Gemini to find information and get things done for you across your Google apps – like Maps, Calendar, Gmail, and YouTube Music. It’s multitasking made easy.
The dependable all-day battery.
The Adaptive Battery on Pixel 9a can last over 24 hours. Need even more? Turn on Extreme Battery Saver to make it last up to 100. That’s big energy.
Amazing photography made simple.
Take photos and videos so amazing, you won’t believe you actually took them. Capture small details, create perfect group shots, and even get vivid ones at night.
That new-phone feeling every few months.
Your phone keeps getting better over time with automatic Pixel Drops – boosts of helpfulness like camera updates, brand-new features, and more.
Google Tensor G4. The power behind AI on Google Pixel.
Pixel 9a uses Google’s most powerful chip yet, Tensor G4 – just like Pixel 9 and Pixel 9 Pro. It’s built for our most capable AI like Gemini, and cutting-edge photos and videos.
The amazingly high-res Actua display.
The 6.3-inch Actua display is sharp, vibrant, and 35% brighter. It runs fast, up to 120Hz, for smooth gaming, scrolling, and switching between apps.
Gemini. Your built-in AI assistant.
Chat with Gemini to supercharge your ideas. Just hold the power button to start writing, planning, learning, and more.
Display quality
The 6.3-inch pOLED display features a resolution of 2424 x 1080 pixels, providing clear visuals and vivid colors. With a peak brightness of 2700 cd/m2 and a contrast ratio of 1000000:1, images appear in various lighting conditions. -
Camera capabilities
Equipped with a 48 megapixel wide-angle lens and a 13 megapixel ultra wide-angle lens, the Google Pixel 9A excels in photography. It supports various camera modes, including Night Sight and Magic Eraser, making it easy to capture and enhance images. -
Battery life
Featuring a 5100 mAh battery, this smartphone provides usage on a single charge. Support for fast charging and wireless charging through Qi standards ensures quick power boosts when needed. -
Connectivity options
The Google Pixel 9A supports 5G, Wi-Fi 6E, and Bluetooth 5.3, making it capable of data transmission. This device is suitable for streaming, browsing, and connecting with various devices seamlessly. -
Security features
Incorporating the Titan M2 security module, this smartphone ensures protection for personal data. Features like face unlock and fingerprint reader provide convenient and secure access.
- Google Pixel 9A - obsidian - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- GTF7P
- Display
- pOLED display - 2424 x 1080 pixels - 6.3" - 422.2 ppi - (120 Hz) - 20:9 - P-OLED - HDR - Corning Gorilla Glass 3 (scratch resistant glass)
- Processor
- Google Tensor G4 - with Titan M2 security
- Memory
- RAM 8 GB / 128 GB
- Operating System
- Android 15
- Main Camera
- 48 Megapixel - wide-angle lens - f/1.7 - focus: automatic
- Second Camera
- 13 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 13 Megapixel - ultra wide-angle lens - f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6E, Bluetooth
- Security Devices
- Face recognition, fingerprint reader
- Connectors
- USB-C
- Wireless Charging Standards
- Qi
- Protection
- Water-resistant, dust-resistant, fingerprint-resistant
- Obsidian
- 73.3 mm x 8.9 mm x 154.7 mm
- 185.9 g
- Repairability Index
- 8.7 (out of 10)
- Specific Absorption Rate (SAR)
- 0.99 W/kg (head) , 1.39 W/kg (body) , 2.79 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- GTF7P
- Form Factor
- Touch
- Protection
- 73.3 mm
- 8.9 mm
- 154.7 mm
- 185.9 g
- Body Colour
- Obsidian
- Body Material
- Matte composite back, satin aluminium frame
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 15
- Intelligent Assistant
- Google Gemini
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS, NavIC, GNSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- EDGE, HSDPA, HSPA+, LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 800, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 14, Band 17, Band 18, Band 19, Band 20, Band 21, Band 26, Band 28, Band 30, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 66, Band 75
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700 PS, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1500 upper, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, FDD 1700 - 2110 AWS-3, FDD 1500
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n79, n40, n12, n26
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, n12, FDD 850
- NFC, Wi-Fi 6E, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyroscope
- Security Devices
- Security Technology
- Face Unlock
- Additional Features
- Dual microphones, MIMO technology, Fast Charging, Google Cast, dual stereo speakers, Adaptive Battery technology, Trusty (Trusted Execution Environment), Emergency SOS, Built-in VPN powered by Google One, End-to-end security designed by Google, Tensor security core, anti-phishing, anti-malware protection, Titan M2 Security Module, 7 years of Security Updates, Feature Drop updates, 7 generations of OS upgrades, Crisis alerts, Car Crash Detection, Safety Check, Emergency Location Service, Emergency contacts and medical info, Android Earthquake Alerts System, Theft protection
- RAM
- 8 GB
- Internal Memory Capacity
- 128 GB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 96.1 degree(s)
- Video Resolutions
- 3840 x 2160 (4K) at 30 fps
Main Camera
- Sensor Resolution
- 48 Megapixel
- Sensor Size
- 1/2"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- 82 degree(s)
- Focus Adjustment
- Automatic
- Digital Zoom
- 5x
- Camera Modes
- Panorama, portrait mode, 4K Timelapse, Night Sight, Long exposure mode, Top Shot, Frequent Faces, Cinematic Pan, Real Tone, Face Unblur, Magic Eraser, Portrait Light, Astrophotography timelapse, slow motion video at 240fps, Macro Focus, Photo Unblur, Audio Magic Eraser, Macro Focus video, Best take, Add Me, Auto Frame, Reimagine, Night Sight timelapse
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps
- Electronic Image Stabiliser (EIS), Stereo Recording, HEVC (High Efficiency Video coding), 4K Timelapse with stabilisation, 4K Cinematic Pan video stabilisation, 4K Locked video stabilisation, 1080p Active video stabilisation, Fused video stabilisation, speech enhancement, Super Res Zoom up to 8x, AVC (H.264), Wind noise reduction, Magic Editor, Quad PD Dual Pixel with OIS & CLAF
Second Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Size
- 1/3.1"
- Lens Type
- Lens Aperture
- F/2.2
- 120 degree(s)
Display
- pOLED display
- Technology
- P-OLED
- Diagonal Size
- 6.3"
- Display Resolution
- Pixel Density
- 422.2 ppi
- Aspect Ratio
- 20:9
- Max Brightness
- 2700 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- Refresh Rate
- 120 Hz
- Contrast Ratio
- 1000000:1
- Protection
- Actua display, Smooth Display (60 to 120 Hz)
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5100 mAh
- Wireless Charging
- Qi
- Battery Endurance per Cycle
- 3139 min
- Battery Endurance in Cycles
- 1000
- Run Time Details
- Mixed usage: up to 30 hrs , Mixed usage (Extreme Battery Saver): up to 100 hrs
- Ingress Protection Rating
- IP68
- Repeated Free Fall Reliability Class
- Class A
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- SIM card removal tool, USB-C to USB-C cable (1 m)
- Limited warranty - 2 years
Sustainability Information
- 8.7 (out of 10)
- Repairability Class
- Class B
- Product Recycled Content
- 23 % - recycled materials
- Packaging Recycled Content
- 100 % - plastic-free
