Google Pixel 7 128GB - Obsidian
Quicklinx: H08VWS00 Mfr#: GA03923-GB
Colours:
  • Android
Meet Pixel 7. Powered by Google Tensor G2, it’s fast and secure, with amazing battery life and the advanced Pixel Camera. Take beautifully authentic, accurate photos with Real Tone and stunning video with Cinematic Blur. And with the certified Titan M2 security chip, Pixel helps protect your personal data.
The brains behind Pixel 7.
Google Tensor G2 makes Pixel 7 faster, more efficient, and more secure. And it delivers even more helpful features and the best photo and video quality yet on Pixel.
It’s everything a battery should be.
Pixel’s Adaptive Battery can last over 24 hours. Turn on Extreme Battery Saver, and the battery can last up to 72 hours. And your Pixel charges super fast.
A super bright screen.
It’s easy to see what’s on your Pixel screen. It adjusts to high brightness in sunshine, and automatically dims in the dark.
The dream display.
The Pixel 7 display is super sharp, with rich, vivid colors. And it’s fast and responsive for smoother gaming, scrolling, and moving between apps.
Find it fast.
Pixel searches your entire phone and the web to quickly find what you’re looking for – a contact, app, screenshot, setting, and more.
Just talk to type.
Use your voice to type, edit, and send texts and emails with Assistant voice typing. It’s fast and accurate, and even works with emoji.
Hands-free help without saying "Hey Google."
If your hands are full, just say "Answer" when your phone rings or "Stop" when an alarm is going off – without needing to say "Hey Google."
Translate languages in real time.
With Live Translate, you can interpret face-to-face conversations in 48 languages, chat in real time, and translate menus with your camera.
Pixel just keeps getting better.
Every few months, your Pixel gets Feature Drops – software updates with new and improved features, tricks, and tips.
The all-around advanced camera.
The Pixel 7 Camera takes incredible photos and videos in stunning color and detail. And with Cinematic Blur, you can now bring cinematic quality to your videos.
Get way close from far away.
The Pixel 7 Camera includes Super Res Zoom, so you can get super sharp close-ups, without an extra telephoto lens.
Amazing video recording.
The Pixel 7 Camera records video with brighter, more vibrant colors and higher contrast. It makes landscapes more epic and moments more dramatic.
Selfies for everyone.
Guided Frame helps people with low vision take the best selfies. It uses audio and haptics to guide a face right into frame.
Make distractions disappear, just like that.
Easily remove distractions, like photobombers, with Magic Eraser in Google Photos. Or change the color and brightness so an object blends right in.
Unlock your phone quickly.
With Face Unlock, just glance at your Pixel to unlock it quickly. Or tap to unlock with Fingerprint Unlock.
  • Everyday moments made easier
    Pixel 7 is super-fast and responsive, with an adaptive battery and so much more.
  • All-around incredible photos and videos
    Pixel 7's dual rear camera system helps you capture memories in stunning 4K color and detail. And with Cinematic Blur, you can now bring incredible quality to your videos.
  • Fit more friends in the frame
    The front-facing camera now has a 92.8° ultrawide field of view for group selfies and epic backdrops. And with its bigger sensor and sharper lens, it provides better low-light photography - you can even document it all in 4K resolution.
  • Secure to the core
    Google's Titan M2 chip is tested against some of the same rigorous protection guidelines trusted for identity, SIM cards, and bank card security chips.
Google Pixel 7 - 5G smartphone - 128 GB - GSM
5G smartphone
Display
Full screen 6.3inch FHD+ (1080x2400) OLED
Google - with Titan M2 security
RAM 8 GB / 128 GB
Main Camera
50MP Octa PD Quad Bayer wide camera
Front Camera
10.8 MP
Service Provider
Not specified
Connectors
USB-C
Protection
Water-resistant
Smartphone
Touch
Protection
Water-resistant
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Intelligent Assistant
Google Assistant
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
Input Device
Multi-touch
Communications
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
RAM
6 GB
Internal Memory Capacity
128 GB
Front Camera
Sensor Resolution
8 Megapixel
Main Camera
Focus Adjustment
Automatic
Digital Zoom
7x
White Balance
Custom
Display
Colour Depth
16.7 million colours
HDR
Refresh Rate
60 Hz
Contrast Ratio
100000:1
HAC (Hearing Aid Compatible)
SIM card removal tool, Quick switch adapter, USB-C to USB-C cable (1 m)
